DIAdem
Data Plugin
In a data plugin, what code do I use so that lines of data will be imported after seeing "[Data]".  Currently this data is in a .csv format
Larry
(3,807 Views)
Larry,
You can read the file line by line until you find the "[data]" tag. Please see the information for DataPlugin developers and check for "GetNextLine"
Then you can probably use the string block to read the values.
Please provide an example file if you want me to provide some example code
Andreas
(3,802 Views)
ThanksSmiley Happy
(3,797 Views)
