DIAdem
Data Point Not transfered to report Panel
Hi There,
I would like to know if there is any means of placing a label(text information) next to a data point in VIEW? I tried transfering the graph to REport thinking I can place a text object but while doing so the data point is not transfered. Can you please suggest me a means where I can have the data point and a text feild next to indicate which would define the data point.
Waiting for your earliest response.
Thanks, Priya
(3,440 Views)
Hi Priya,
There is no way to do what you've explicitly asked for in DIAdem 11.0 or earlier versions.  In REPORT you can configure a text to appear as part of the marker with the "Line and points" curve type.  In VIEW you can add a UserCommand to display descriptive text in the graph legend or a nearby textbox which will change as you move the cursor from point to point.  But there is no way to configure a text to display next to the data points on the VIEW graph.
Brad Turpin
DIAdem Product Support Engineer
(3,426 Views)
