DIAdem
DataFileLoad vs DataFileLoadSel
I'm trying to understand the speed issues when using one command versus the other, and if there is any better way to speed up this process. Here is my situation.
I have a file with 300+groups and 12 channels.  Rather than loading all the data and removing unwanted groups/channels, my current script uses DataFileLoadSel to get the appropriate channel of data I want from each group. When all the data is loaded the data portal shows all the groups with 1 channel of data in each  which I then post process.
The data file is custom .csv file where I wrote a plugin appropriate convert the raw data into the groups and channels that I want. The plugin indexes the file properly and there are no issues with it. I also wrote a seperate utility to convert the raw data to TDM format which I can then import as above.
When I DataFileLoadSel a channel from the .csv file it takes ~5 secs per channel to load, so it takes nearly 30 min to complete. If I use the TDM version it takes 1 sec
(3,266 Views)
Please follow this link: http://forums.ni.com/ni/board/message?board.id=60&thread.id=7869
(3,259 Views)
