DIAdem
DataFileSaveGroup?
I'm looking for a way to save all channels o a certain group. It is very uncomfortable to do it with the DataFile SaveSel -command because I don't the number and names of channels.
Background: a mesurement yielts a variable nuber of channels. At last alle mesurement channels (one group) have to be saved.  But there are other channels (in other groups)  with data not to be saved.
(4,032 Views)
I am posting a little function that will be handy in that situation. It is generating a channelselection string from a group referenced by its name or index.You can use the channelselection string in the save function later.
function getGroupSel(group)
  if not isnumeric(group) then group = Groupindexget(group)
  chnsel = ""
  for i = 1 to groupchncount(group)
  chnsel = chnseladd(chnsel, "["&cint(group)&"]/["&cstr(i)&"]")
  next
  getGroupSel = chnsel
end function
msgbox GetGroupSel(1)
Ingo Schumacher
Systems Engineering Manager CEERNational Instruments Germany
(4,011 Views)
Ok, this combination of GroupChnCount() and ChnSelAdd() function solves the problem.
I was wondering, that a GroupSave -function seems not to exist.  It should be a normal case that a hole group is to be saved.
(4,007 Views)
I agree. I filed a product suggestion.
Ingo Schumacher
(4,004 Views)
