DIAdem
DataFinder integrated in UserDialog via ActiveX
Hi everybody,
i have a question about using ActiveX-Elements in an UserDialog:
I want to use an UserDialog to find files, display them in a ResultsList und give the possibiltiy to select one, to load it or write the path into a variable.
My first idea was to use an ActiveX-Element. But i don`t know how to provide the ResultsList from the DataFinder in an ActiveX-Element and to display it there.
Does somebody know how it works or can give my a hint?
Thanks, Marko
(3,626 Views)
Hi Marko,
As I know there is no ActiveX control for the DataFinder available. But of course you can use the DataFinder functionality in SUD. How this can be used explains the example "Search and Evaluation Functions in User Dialog Boxes" in DIAdem 11.
Greetings
Walter
(3,605 Views)
