DIAdem
DataP with Loop
Hello everybody,
I am currently working on a programm, which is using data from an Excel to coordinate a movement between the x-/y-/z-axis of a machine. The programm uses a loop to get the coordinates from the Excel in every step. My problem is that i can not display the coordintaes via DataP for every movement.
Does anyone have an idea?
(2,042 Views)
What is "DataP"?   Data Portal?
How quickly do you need to perform the updates?  Or stated another way, what is the rate at which you wish to fetch the data from Excel / the machine and display an update in DIAdem?
A better approach may be to use DIAdem's DAC module with a data acquisition card and read the data directly from the machine.
(1,896 Views)
