DIAdem
Datafileimport question?
I build a filelist and Call DataFileImport(DataFileName, [FileImportFilter], [PartialMode])
to important it. But I do not know how to set [FileImportFilter] and [PartialMode]. The DIAdem Help does not help. My data file is attached.
(3,592 Views)
PartialMode: Specifies whether the DataFileImport command displays the dialog box for channel selection.
If you set this parameter on TRUE a dialog appears in which you cam specify which channels you would like to load.
With FileImportFilter you specify the kind of data format of the file you would like to load:
TDM DIAdem TDM format
DD8x DIAdem DAT format
asciiFilter ASCII format
Excel EXCEL format
LVM LabVIEW LVD format
But in your case you must use the ASCII import function with the following commands:
call asciiassocset(DATADRVUSER & "Testfile.CSV", DATADRVUSER & "Test.stp")
call asciiload(DATADRVUSER & "TP_53_CTz10439_mh5_mh4_PHabc_0F1_103626.csv")
call asciiassocdel(DATADRVUSER & "TP_53_CTz10439_mh5_mh4_PHabc_0F1_103626.CSV")
More in
fos to the commands you find in the DIAdem help.
(Note: For DIAdem 9.1 we are working on a CSV import filter. Than it will be possible to use the following command Call DATAFILEIMPORT("TP_53_CTz10439_mh5_mh4_PHabc_0F1_103626.csv","",0))
I hope this will help you
Greetings
Walter Rick
(3,592 Views)
