DIAdem
Dataplug In won't inport
Hello
I am trying to load a data plug in which doesn't seem to import into my list of available data plugins.
When I try to reinstall the plugin I am asked if I want to overrite the existing plugin which leads me to believe it is loaded somewhere.
I am using the 2015 evaluation version of DIAdem (64 bit).  The data plugin I am trying to load works on other machines with copies of DIAdem juts not mine.
Tim
(4,609 Views)
Accepted by topic author smoothdurban
Which kind of dataplugin do you use.
VBS dataplugins should show up in 32 and 64bit DIAdem
but there are some C++ dataplugins that do only exist for 32bit.
(4,605 Views)
That could be it
I have a C++ plug in and my version of DIadem is 64 bit.  My colleagues machine is 32 bit.
**Update***************
I was able to install the 32 bit version and it works!
Tim
(4,595 Views)
Please check the dataplugin page, For some of them there is already a 64bit version.
(4,573 Views)
