DIAdem
Dataplugin (vbs) encryption seems to be on all the time
Hi Group,
I have made a custom vbs dataplugin.  On the machine that it was developed, the dataplugin can be edited. When I make a uri and export it (without encryption)  and then load into another machine. The second machine, now has the vbs encrypted!
I was expected that since I exported the dataplugin as just "export" and not  "export encrypted" that the loaded uri would on a second machine would be able to edit it.
But that is not my experience in DIAdem 2018 64.
How can I edit the dataplugin on a uri installed dataplugin?
Paul
(3,278 Views)
Accepted by topic author Pesmith8
The behavior changed for simple double click the uri file.
If the file should be editable you need to use the import button in the DataPlugin Settings dialog.
P.S.: This was done to reduce the amount of editable vbs script in the accessible space to reduce security issues.
(3,250 Views)
Thanks Andreas!
(3,244 Views)
