DIAdem
Dataportal update after calculations are done
I have several calculations that I run on a .CSV file and the data takes a long time to load when I am running it from the reports view.  If I run the same scripts manually from the script view the Dataportal does not update each line at a time but run all the calculations and then refreshes the dataportal when it is all complete is this a glitch or is there a way in the script that I can force it to only update the dataportal on completion ?
(5,046 Views)
Accepted by topic author Jcheese
As far as I know data portal is only refreshed on complete if you start your script in non debug mode (Ctrl+F5)
But there is a methodto control this in your script
dim oldstate : oldstate = UIAutoRefresh
UIAutoRefreshSet False
UIAutoRefreshSet oldstate
(5,031 Views)
