DIAdem
Date/Time scaling in script doesn't seem to work
I'm trying this code to alter my axis' scaling based on a previous event search. I'm getting an error when I try "oMy2DAxisSystem.XAxis.Scaling.Begin" = <Date> saying "Numeric value necessary". So it seems that I'm not actually able to change the property "oMy2DAxisSystem.XAxis.Scaling.Type"
Set o2DAxisXScaling = oMy2DAxisSystem.XAxis.Scaling
oMy2DAxisSystem.XAxis.Scaling.AutoScalingType = eAxisAutoScalingBeginEndManual
o2DAxisXScaling.Type = e2DxScalingDateTime
oMy2DAxisSystem.XAxis.Scaling.Begin = CDate(Data.Root.ChannelGroups(1).Channels("DateTime").Values(indexbeginning))
oMy2DAxisSystem.XAxis.Scaling.End = CDate(Data.Root.ChannelGroups(1).Channels("DateTime").Values(indexend))
(3,262 Views)
Mattrad,
Going by the Help documentation, it looks like that function is expecting a numeric value which signifies a certain type of scaling. Take a look at the link below, and see if that clears things up.
Property: Type for 2DAxisXScaling
aprillest
(3,228 Views)
The error occurs on this line:
not when setting the type.
(3,207 Views)
I tried to replace e2DxScalingDateTime with 0, but It changes nothing. I'm pretty sure they are both 0.
(3,206 Views)
Hi mattrad,
You have to assign the corresponding DBL values to the X axis scaling that DIAdem displays as datetimes.  Luckily, there's an easy "DValues" property you can use instead of the usual "Values" property to request the DBL representation of a datetime channel's value.  I also added an explicit datetime format string, in case that's helpful:
indexbeginning = 25
indexend = 40
Set DateTimeChannel = Data.Root.ChannelGroups(1).Channels("DateTime")
Set oMy2DAxisSystem = Report.ActiveSheet.Objects("2DAxis1")
oMy2DAxisSystem.XAxis.Numbers.Format = "#mm/dd/yyyy"
oMy2DAxisSystem.XAxis.Scaling.Begin = DateTimeChannel.DValues(indexbeginning)
oMy2DAxisSystem.XAxis.Scaling.End   = DateTimeChannel.DValues(indexend)
Call Report.Refresh()
Brad Turpin
DIAdem Product Support Engineer
(3,176 Views)
