DIAdem
Debugger doesn't work with Diadem 2012SP1b version 64bit Win7
I downloaded the latest version of the MS Script Debugger. (http://www.microsoft.com/en-us/download/details.aspx?id=22185)
When I try to start it in Diadem a message appears: "The software is not able to work with the recent version of the Microsoft-Debugger 1,0,0,7234. Script will be started in normal mode."
Diadem Version: 12.0.1f5436 SP 1b
Is there any solution for this problem?
(6,722 Views)
Hi budist,
That link you provided just took me to a generic Microsoft site, not a download site.  What "debugger", exactly, did you download?  To my knowledge the Microsoft VBScript debugger hasn't changed in about 8 or 9 years.
Brad Turpin
DIAdem Product Support Engineer
(6,694 Views)
Hi Brad,
sorry for the wrong link!
I downloaded the
"Script Debugger for Windows NT 4.0 and Later"
Version:1.0
Date Published:7/14/2005   --> 8 to 9 years, yes Cat Frustrated
File name:scd10en.exe
File size:654 KB
many wrote, that it worked. Is this the right one?
I wanted to debug Diadem scripts sometimes, for a better understanding of the code.
(6,691 Views)
Hi budist,
That looks like the right version, and it certainly works with DIAdem 2012 SP1 and should also work with DIAdem 2012 SP1a or DIAdem 2012 SP1b (haven't tested it myself though).  What are you doing exactly when you report... "When I try to start it in Diadem"?  Are you clicking on the blue triangle icon in the SCRIPT panel with the tip strip "Debug", or are you doing something else?
Brad Turpin
(6,683 Views)
Accepted by topic author budist
yes, its the button beeing also related to F5.
edit: I uninstalled and installed it again and now it seems to work. I did that before. Well, thats how things are sometimes...
Thanks for your time!
(6,681 Views)
Glad it got resolved. I installed the same version of the Debugger on my Win7 64-bit with DIAdem 2012 SP1a and it works fine ...
Weird software interaction - happens more often than I would like to believe, everywhere, including my phone ...
Otmar D. Foehner
(6,656 Views)
