DIAdem
Debugger won't show variable
Hey,
Currently I cannot evaluate the values of any variables in a script when I'm at a break-point.
The current variable contents page is always empty, any watch value I setup returns "???" and when I select a variable by text and mouse over also nothing.
I've managed to use msgbox() to finish up what I was currently working on, and my scripts run just fine.
I've attached images with an example and my Diadem version and script engine.
Alex R
Message 1 of 10
(7,066 Views)
Hey Frisbert,
I currently have the same issue you had and only get "???" for every variable in the Debugger.
Since your question is already 3 months old I hope you found out the solution yourself and could tell me how you solved it. Because using only msgboxes in a script with 100,000 lines of code can be annyoing and difficult - but I'm sure you realized that yourself.
Couldn't find anything in the web about this issue besides your question btw.
Thank you!
Benedikt
Message 2 of 10
(6,372 Views)
Hey,
The only solution that I've seen work is a clean re-install.
My coworkers have done this to resolve the issue when it happened to them, I'm still using msgbox debugging.
Alex R
Message 3 of 10
(6,352 Views)
Hi All,
I also mainly use MsgBox() and LogFileWrite() for debugging a DIAdem script.  For DataPlugin debugging, I usually output the same sort of information to properties in the Data Portal.
I know DIAdem experts who swear by the DBM() messaging approach, though, so that's another option to consider.
Brad Turpin
Principal Technical Support Engineer
NI
Message 4 of 10
(6,326 Views)
Hi All,
I've just returned to using DIAdem after a break of a few months and I know find I have this problem too. Are NI aware? Is there a solution other than a re-install yet?
Simon.
Message 5 of 10
(5,019 Views)
you do not need to reinstall DIAdem completely
it's enough to "reset" DIAdem
therefore, you have to close DIAdem
then you go to %USERPROFILE%\AppData\Local\National Instruments\DIAdem
there are the settings folders for every DIAdem version
rename the folder which belongs to the DIAdem version with the issue
now, when you start DIAdem again, a new folder with default settings for the version is created
DIAdem debugger should show variables now again
Message 6 of 10
(4,997 Views)
I'm afraid this didn't work for me. The problem remained even after a new folder was created.
I'm in conversation with NI and their solution is a reinstall....
Regards.
Message 7 of 10
(4,991 Views)
Just before trying a full reinstall, NI Tech Support made the following suggestion, which worked:
Go to C:\Program Files\National Instruments\DIAdem 2020 and run DIAdemStart.exe as an Admin.
This re-associated the installer registry options.
Regards.
Message 8 of 10
(4,981 Views)
Hi all,
For anyone else who runs into this problem in the future, there is now a public article detailing steps to try here, including the steps in this forum thread.
Cheers,
Nick
Message 9 of 10
(4,966 Views)
Thanks for the update, I followed the instructions from the linked post and it fixed the issue for me in DiAdems 2018.
Message 10 of 10
(4,959 Views)
