DIAdem
Decode Hex Vector
Hi
I am using Diadem to retrieve data from a server using the ADODB Object. So far I am able to retrieve the data with out problems. I reatrive a HEX string containing the vector data, but apparently the data came codified or compress, I am not sure.
I have tried to find a pattern in the data since there is some repeated values within the vector, but so far I cannot figured it out.
Attached are the HEX string and the vector to which should be converted.
I know my question is a little bit unrelated but I would like to know If some one has an idea of how to try to decode this data.
Thank you in advance
(4,846 Views)
Hello dslemusp,
Before, I would like to know a little more about how their data is acquired and how is analyzing the Diadem.
Thanks for your contact.
Regards.
Wesley Rocha
Wesley Rocha
Application Engineer
National Instruments Brazil
Visite a nossa comunidade em PORTUGUÊS!!!
Certified-LabVIEW-Associate-Dev
(4,721 Views)
