DIAdem
Default line style in Diadem Report
Hej
I do not like the default line thickness of 0.35 mm I get when creating a new graph in Diadem Report.
Is there a way to change this value permanent?
Best regards
Anders
(3,644 Views)
Hi Anders,
The short answer is that there is no cool built-in feature that customizes the properties of curves created by dragging and dropping channels onto an arbitrary layout in REPORT.  The long answer is that you can get what you want with a line width other than 0.35 by using an unusual plotting mode known as "Curve Expansion".  In "Curve Expansion" you reference channels by channel name only-- no Group information, and REPORT automatically plots every valid set of XY channels that satisfies that pure channel name reference.  In this "Curve Expansion" mode you can specify how the various curves from a single curve configuration should appear-- with color, symbol, line width, etc.  You can also specify how many different permutations of these quantities to go through before repeating them.
You can further set up DIAdem to load a particular layout (TDR file) every time you click on the "New Layout" icon at the top left of the REPORT panel.
If this sounds interesting, ask for more details,
Brad Turpin
DIAdem Product Support Manager
(3,628 Views)
Hej Brad
Thanks for your answer.
I have been into all of your suggestions but what I would like to see instead of a hard coded value, the possibility to write prefered line width into the desktop.ddd file.
Maybe a feature for the future
Best regards
Anders
(3,622 Views)
