DIAdem
Delete channels (by name) in any group
I load a few dozen groups, with some similar (and some unique) channel names.
The first group I load is the template of data I "care" about, and I want to delete all channels in all groups that don't match one of those "template" names. Having issues. Tried multiple solutions.
Dim ChannelTemplate, i
Set MyChannelNames = Data.GetChannels("[2]/*") 'Gather the channel names from Template
i = 1
Set ChannelTemplate = Data.GetChannels(Str(MyChannelNames(i).Name)) 'equal to all channels that meet this name... but it only finds it in this group
Call ChnDelete("*/" &TemporaryString) 'Delete all channels found in the above line
(7,116 Views)
Hello
You might try the code below.   The trick is that you have to delete the highest numbered channel first in the Channel list.
The code below will sort the channel numbers and then delete from the highest number down to the lowest.
Paul
(7,092 Views)
Hi rlbodor,
If your DIAdem version is new enough, I prefer passing the channel collection variable to the Data.Remove() method:
Set MyChannels = Data.GetChannels("[1]/*")
Call Data.Remove(MyChannels)
Brad Turpin
DIAdem Product Support Engineer
(7,060 Views)
I may be wrong but reading through teh question again, rbodor wants to delete those channels in groups 2 and following which DO NOT exist in group one.
The previous two answers show a solution to delete the channels which DO exist
Try the example in the attached file.
Andreas
(7,033 Views)
