DIAdem
Deleting values smaller than the desired increment
when performing a multibody simulation with a fix step size I recieve in the output data some additional values smaller than the normal increment or the values are duplicated. The time-channel looks like:
0
0.0002738
0.001
0.002
0.002
0.003
0.004
I think with a simple script I can delete the additional valuues (here 0.0002738, 0.002).
E suggest this code, but It doesn't work:
  Dim timechannel,i, dif
  timechannel = "[1]/TIME"
  i = 2
  Do while i < (Val(ChnPropGet(timechannel, "length"))-1)
    dif = CHD(i,timechannel) - CHD(i-1,timechannel)
    if dif = 0.001 then
      MsgBox("i="& Str(i) & " Wert:  " & CHD(i, timechannel) & " i-1=" & Str(i-1) & "Wert: " & CHD(i-1, timechannel) & " dif= " & Str(dif))
      i = i+1
    else
      MsgBox("i="& Str(i) & " Wert:  " & CHD(i, timechannel) & " i-1=" & Str(i-1) & "Wert: " & CHD(i-1, timechannel) & " dif= " & Str(dif) & " ->DELETE")
      Call DataBlDel(timechannel,i,1) '... ChnNoStr,ChnRow,ValNo,ValDelOnly
    end if
  loop
 The problem is that sometimes the variable dif recieves the value 0.001 but anyway the value at this position is deleted. I don't know why.
I addedthe script and simulation data.
Thanks for help
Gabriel
(3,885 Views)
Hello fischerg,
I think there is a more efficient way to do this. What version of DIAdem are you using ?
Or better, what is the oldest version of DIAdem this script should work with?
Andreas
(3,884 Views)
I use DIAdem 11.0. Sometimes I use 10.0, but it's not necessary that your solution works with this.
I'm curious what you suggest.
Gabriel
(3,880 Views)
Accepted by topic author fischerg
Hello Fischerg,
let me know how this works:
Option Explicit
Dim   timechannel,CLength,CNumber,dBase,Epsilon,Limit,K,CurrValue,Delta
CLength     = Val(ChnPropGet(timechannel, "length"))
CNumber     = CNo(timechannel)
Epsilon     = 0.00001
Limit       = 0.001 - Epsilon
dBase = CHDx(1,CNumber)
For K = 2 To CLength
  CurrValue = CHDx(K,CNumber)
  Delta     = CurrValue-dBase
  ' Compare using Epsilon value. Comparing float numbers
  ' with "=" doesn't always work
  If ( Delta < Limit ) Then
    CHDx(K,CNumber) = NULL
  Else
    ' Set new base
    dBase = CurrValue
  End If
Call ChnCharacter(timechannel)
' remove tagged values. If there are more channels in parallel to the "TIME" channel,
' those can be adjusted with the same call. See ChnNovHandle online help for details
Call ChnNovHandle(timechannel,"","Delete","X",1,1,0)
(3,876 Views)
Hello Andreas,
Thank you, it works very well.
Gabriel
(3,872 Views)
