DIAdem
Deselect one item in listbox on Dialog Box by using Script
I have a ListBox with a couple of listitems on Dialog Box.
I have a script to select listitem for doing somthing. Could you please help how to deselect that selected listitem with script?
Gman
(3,120 Views)
In this example SUD I have attached, I fill a listbox with some numbers on startup.  As soon as i make a selection, it deselects.  Basically, do:
ListBox.Selection = -1
(3,103 Views)
Hi gsklyr,
Thank you for your advice.
It's my fault not to explain my question clearly.
The following is what I want to do:
1. Click one listitem to trigger a "ListBox1_EventChange" for doing something.
2. Deselect the selected listitem.
3. Repeat step1.2 (clicking same listitem).
Now the issue is I only can trigger "ListBox1_EventChange" once by clicking the same listitem before I click other listitems, even I reset Listbox1.selection to -1 as your suggestion.
By the way I cannot open your example.
Gman
(3,047 Views)
Accepted by topic author gq
'-- SUD script file
'-- Created on 10/08/2019 09:04:29
'-- Author:
'-- Comment:
Option Explicit  'Forces the explicit declaration of all the variables in a script.
'Note: In this area area you can program auxiliary variables and functions that you can use in the entire dialog box.
Sub ListBox1_EventInitialize(ByRef This) 'Created Event Handler
  Call ListBox1.Items.RemoveAll()
  Call ListBox1.Items.Add(" - 1 - ", 0)
  Call ListBox1.Items.Add(" - 2 - ", 1)
  Call ListBox1.Items.Add(" - 3 - ", 2)
  Call ListBox1.Items.Add(" - 4 - ", 3)
End Sub
Sub Button1_EventClick(ByRef This) 'Created Event Handler
  ListBox1.Value = -1
  ListBox1.Selection = -1
End Sub
Sub ListBox1_EventChange(ByRef This) 'Created Event Handler
  If ListBox1.Selection = -1 Then
    Call MsgBox("De-Select Event")
  Else
    Call MsgBox("Regular Event")
  End If
End Sub
SUDSUD
Instead of the button, you can have th last line of your event change be listbox1.selection = -1 to clear
Sorry the key is to clear the value as well... listbox.value = -1 (read your post more carefully)
(3,040 Views)
Hi gsklyr,
I'm really appreciated your response. It really help me.
Here is my lesson from practice:
These two commands,ListBox1.Value = -1
  ListBox1.Selection = -1, cannot be put inside "ListBox1_EventChange(ByRef This)".
Spoiler
Which can cause an infinite loop.
Gman
(3,018 Views)
