DIAdem
Determining time at a given channel value
I'm new to DIAdem so I apologize if this is a stupid question.
I am collecting TDMS data from a test stand, with each "cycle" being a different group. I need to determine the amount of time a channel stays within range (actually two ranges, one high and one low) for each group. I need to do this automatically as there are hundreds of thousands of cycles that this operation needs to be performed on. There are a couple more operations I need to do, but they are simple enough that I think I can figure them out if I can get this one done. Anyone have any examples/advice? A sample of my data is attached if that helps...
Thanks in advance
(2,660 Views)
Can you also attach your data file please (TDM, TDMS, CSV, ...)?
Your TDV file only describes the VIEW layout but does not contain any channel data values...
Regards
Christian
CLA, CTA, CLED
(2,624 Views)
