DIAdem
Diadem 2020 SP1 offline installer doesnt work
Downloaded the installer, started Install.exe and got following error, how can install it?
I dont want to use the packagemanager installation, as im testing this version and we will have to make a volume licence installer, so the package manager version its not useable.
(2,692 Views)
When i try to run the Install.exe from BIN directory, i got following error:
(2,670 Views)
I got Diadem crashed today multiple times again, but i got new error.
Im i really the onluy one with this version, i got error all the time and Diadem crashes to me all the time, its quite unusable. Now it gives me KERNEL error instead of telling me which line caused the error so now i cant even see which line fot error.
after clicking OK, i got this in logfile. looks strange.
12:35:49 Error:
Error in <Jonas.VBS> (Line: 12, Column: 19):
Error while executing "("C:\LOCAL\Jonas\Jonas_Base.vbs")" command
Error type: UNKNOWN
Error address: 00013048
Module name:KERNELBASE.dll
16 DIAdem system file "DIAdem.G1D" not found !
Program aborted !!
**** DIAdem START Version: 20 on 12.10.2020 at 12:36:44
17 12:43:04 Error:
18 DIAdem DAC or DIAdem VISUAL: NO data structure created.
Please do not enable DAC or VISUAL.
19 ATTENTION: Unknown keywords in file C:\Users\dzcld7s\AppData\Local\National Instruments\DIAdem\2020\Desktop.DDD!
The following lines and blocks will be skipped:
Line Text
167 End_DACEditor;
20 End_Defaults;
Keylist:Paths,File,NovaluePreSetting,AutoEditorName,AutoRouting,RouterHelpLines,AutoTeachLstMode,AutoTeachLstPath,AutoTeachChnMode,NewDlgDefinition,MetaResolution,UseTextAlign,DlgGenerate,ASAMBrowserState,DACEditor,Workspace,DataNewIconSet,GraphNewIconSet,Templat
21 End_Defaults;
Keylist:Defaults,Clock,Scaling,Visual,Scope,Device,Global,
22 End_Defaults;
Keylist:SHELL,DATA,MKS,Visual,Scope,AUTOSEQUENCE,VIEW,GRAPH,SETTINGS,GPI-Extension,Script-Extensions,ANALYSIS
175 Condition: 255;
177 MathsType: 150;
179 ControlType: 10;
181 DataFlags: 60;
183 Report: 10;
185 End_Global;
186 Begin_Clock
191 Begin_Scaling
196 Begin_Visual
201 Begin_Device
211 End_MKS;
212 Begin_AUTOSEQUENCE
220 Begin_VIEW
228 Begin_ANALYSIS
234 Begin_GRAPH
246 End_Desktop;
Line: 246: Unexpected end of file | C:\Users\dzcld7s\AppData\Local\National Instruments\DIAdem\2020\Desktop.DDD
Keylist:Desktop
23 12:43:04 Error:Error has occurred. Refer to logfile
24 12:43:08 Info:
25 Loading file "C:\Users\Public\Documents\National Instruments\DIAdem 2020\Data\EXAMPLE.TDM" ...
26 12:43:08 Info:
27 File 'C:\Users\Public\Documents\National Instruments\DIAdem 2020\Data\EXAMPLE.TDM ' loaded.
&Move...
&Move...
28 12:43:08 Error:Object required: 'navigator.display.currdataProvider'
29 12:43:08 Error:Object required: 'oCurrDataProvider'
30 12:43:08 Error:Object required: 'oCurrDataProvider'
31 12:43:08 Error:Object required: 'Navigator.Display.CurrDataProvider'
(2,661 Views)
And after this, Diadem looks like this. Hmmm im restarting the whole system now...
(2,659 Views)
Please let me know abouyt the OFFLINE INSTALLER FOR DIADEM 2020 SP1.
I installed the Sp1 d2020 from the online installer. i dont get the KERNEL errors.
But D2020 is uninstalled. Its not possible to have bboth versions installed?
As our users are running D2020, i wanted to test D2020 SP1, but it uninstalled the D2020 version, so now i dont have same version as my users, so im confused to be developing our appliacation in SP1, while users run it in D2020. So im afraid of possible incompatibility.
(2,656 Views)
I installed the D2020 SP1 with the online installer, which worked and as im testing it, i dont get errors like in the 2020 version. I must say that i used to work with it like 2 months and got errors everyday.
But please can u look at the error in the first post in this thread, why i cant install it with the offline installer as we will need to make volume installer from it?
thanks
(2,626 Views)
Hello, can you please check whats going on with the D2020 SP1 offline installer?
(2,587 Views)
