DIAdem
Diadem DAC to generate 5V voltage, output by cDAQ-9174 and NI-9263
1.New learner for NI products, purchased one cDAQ-9174 and NI-9263
2.creat one simulated DAC block, to generate 5V voltage, and want to output by cDAQ-9174&NI-9263
3.no 5V voltage out checked by multimeter, instead of  9V voltage out, very strange, pls support to find out the root cause
remark:
1.by test panel in NI-MAX interface, check the NI-9263 AO 0&COM 1 voltage output, it is normal
(1,507 Views)
Accepted by topic author ZGG
Hi ZGG,
I had a look at your DAC scheme an it seems that the output block is not connected.
Double click on the arrow where the wire is connected to the block and select the signal you want to output.
Once the signal is connected, your DAC scheme should work as expected.
Regards
Rainer
(1,465 Views)
Hi: Rainer
      this issue bothered me several days, and it is covered now, tks for your great supporting.
BR
Jack.zhao1
(1,442 Views)
