DIAdem
Diadem Data Format with Single File per Channel Uniquely Named
Hi All,
Is there already an existing format available for storing and loading data in Individual files with unique file names?
ISO MME doesn't work for us because the file names matches the root name not the channel name.
If not, is it possible to make an Export Plugin?
I'm aware of the import but not sure about a custom-made export plugin, I'm not sure.
Was hoping to use something already made slightly customize it for our needs
Chris
Message 1 of 1
(519 Views)
