DIAdem
Diadem VC (viscous criterion) function difference
I found that when calculating VC, there are times when the results differ significantly depending on whether the directive setting is selected as R94 or Euro NCAP. (Sometimes there is almost no difference.) Does anyone know the cause of this difference? According to Diadem help, R94 and Euro NCAP are calculated using the same algorithm.
Message 1 of 1
(303 Views)
