DIAdem
Diadem activating gui... problem
When I open DIAdem, it blocks at  "Activating gui..."
-Everything use to work perfecty,
-I have just reinstaled windows a couple of days before
-Windows updates are disabled
-I didn't install anything else between the moment it was still working and the moment when it stoped working
-The firewall is off
-It just SUDDENLY stoped working for no reason
-It's not the first time that this problem appears, and I all readdy had to reinstall my OS once.
Please help me!
Cheers
Message 1 of 10
(6,021 Views)
Hello  Miles,
did I get it right?
- System was up and running
- You reinstalled windows (XP ?) or just installed over existing windows
- Did you also reinstall DIAdem (which version of it)
- If you say it is not the first time, do you mean that it is not the first time DIAdem stops working
- Do you use a mixture of DIAdem versions?
- Are other NI products installed?
- Did you try a repair installation of DIAdem?
Greetings
Andreas
Message 2 of 10
(6,005 Views)
Hi Andreas,
-yes
-reinstalled
-yes, vesrion11.2
-yes
-no
-yes,labview 8.6
-yes
Message 3 of 10
(6,003 Views)
Hi Miles3,
How long were you waiting for because I know that the first time, it could be a little bit long (several minutes)?
Sincerely
David S.| Certified LabVIEW Associate Developer
National Instruments France
Message 4 of 10
(5,992 Views)
Hello Miles,
maybe this might help to identify the issue, please download dependency walker. Load DIAdem exe into dependency walker and select the menu
Profile->Start Profiling
and run it by hitting OK.
Please post the output here.
Greetings from cloudy germany
Andreas
Message 5 of 10
(5,987 Views)
Hi Andreas,
This software seems really interesting,
I have run the thing as you asked for,
but do not know what kind of outpout you what.
Do you want a "printscreen" and if yes, what part of the window you need most?
thanks a lot
Miles
Message 6 of 10
(5,948 Views)
Message 7 of 10
(5,944 Views)
It is possible to save the content of dependency walker to be read by others.
File->Save As
The Content is saved to an dwi (dependency walker image) file.
So please start Profile in dependency walker and when the
error occures save the dependency waler state to a dwi file.
Please zip this file and post it.
Thanks a lot.
Andreas
Message 8 of 10
(5,938 Views)
Accepted by topic author Miles3
OK I found the solution:
It seems like a a few files are responsable for this, so need to delete them.
1.Make sure you can see all the hidden files in your windows explorer
2.go to documents and settings\"your user name"\local settings\application data\national instruments\DIAdem\2010 and delete all the files in the 2010 folder.
(This path is the one for windows xp.For other versions of windows it's quite similar and you should not spend to much time finding it)
DIADEM WORKS AGAIN
Message 9 of 10
(5,930 Views)
This got me today.  Thanks to Miles3, I'm back in business.
Jim
Message 10 of 10
(4,577 Views)
