DIAdem
Diadem as a service on Microsoft Server 2008
We need to run some Diadem scripts on a server running Microsoft Server 2008. The scripts and Diadem need to run as a service on the server, is this possible? One other thing is that the id used to run the services is a non-interactive id on server.
(5,690 Views)
Greetings JH_61
I have not tried to run DIAdem as a service, but this forum might be worth looking into:
http://forums.ni.com/t5/Machine-Vision/How-to-run-VisionBuilder-as-a-service-in-Windows/m-p/2227124
Extrapolating from what the forum says; it may be possible to run DIAdem as a service just as with any other application by following a tutorial such as the one mentioned in the forum.
Let us know if it works out for you or if you have further questions. Have a nice day.
Luis J.
(5,640 Views)
