DIAdem
Diadem closes 10 sec after start without warning
ERROR:
USED VERSIONS:
DIAdem Version 8.00.981 and
NI Measurment & Automatisation Explorer Version 4.5.0f0
WARNING in DEM_ERRS.001 (German version):
1    **** Fehlerregistrierung am TT.MM.YYYY um HH:MM:SS [Meldungsdatei:COMMON / Textarea:13 / Textnummer:1]
     Objekt "tc1" unbekannt oder nicht offen.
SOLVING:
deactivate windows service: "NI Configuration Manager"
(4,875 Views)
Hi Andreas,
when did this problem first occur? Where there any known changes/crashes on the system before? Does the crash happen every time you start DIAdem?
Please  open the Measurement and Automation Explorer. Are there any error messages when you open the tool?
Kind regards,
Bernd
(4,849 Views)
Dear Bernd, the answers to your questions below:
> No the PC system is new!
When did this problem first occur?
> Step 1: Installing: DIAdem 8.00
> Step 2: Installing: NI Measurment & Automatisation Explorer Version 4.5.0f0 & NI-DAQmx 8.5
> Step 3: Starting DIAdem -> the error occurs
> Yes!
> No!
Please see also my post:
What DAQ Driver or MAX is needed for DIAdem 8.00 & HW: PCI 6034E
http://forums.ni.com/ni/board/message?board.id=60&thread.id=10318
Thanks, Andreas
Message Edited by Andreas (FTE) on 04-29-2009 10:12 AM
(4,845 Views)
Hi andreas,
please see this link: As you will see DAQmx 8.5 is not supported by  DIAdem 8.0.
That means you have these two options: Install an older version of DAQmx or install an actual version of DIAdem (recommended)
(4,821 Views)
Hi All,
If you see DIAdem 8.x close down immediately after completing its launch, it could well be a driver incompatibility for the case that you have DIAdem-DAC (with DAC and VISUAL panels), as was mentioned above.  But there is another situation with identical symptoms that occurs with DAC-less DIAdem (the kind usually sold in the US without the DAC and VISUAL panels).  On my compute this occurs when I install a modern version of DIAdem and DIAdem 8.x on the same computer (not order dependent).
The solution in this case is to manually re-register the VBScript host:
regsvr32 "C:\Program Files\National Instruments\DIAdem 8.10\vbscript.dll"
Brad Turpin
(4,812 Views)
Accepted by Andreas (FTE)
Thanks for your answers!
I have now deinstalled all new DAQ(mx)driver and installed NI-DAQ 6.9.3 Traditional Driver (includes MAX 2.2.0.3010) and DIAdem 8.0 works fine.
(4,782 Views)
Hi Andreas,
thanks for your response, good to hear that it's working now.
(4,768 Views)
