DIAdem
Diadem contour plot intersection curve data points
Hi, I am using the intersection curves feature of contour plots in Diadem 2015. Everything is working OK but my x and y channels have different numbers of data points. It seems like the extra data points in the higher resolution channel are included in the contour plot, but the intersection curves are rescaled to both have the number of data points of the smaller-size channel. This might make more sense if you can see the actual VIEW window:
The plot in the lower right should have 1024 data points but is constrained to have 30 data points, the resolution of the vertical channel. Is there a way to get a cross section with the full resolution?
(3,894 Views)
Accepted by topic author leeaspitarte
Are you using triplet structure or matrix structure for the displayed data?
Highest Regards,
Paul
(3,836 Views)
Thank you. Using a matrix plot fixed the problem.
(3,812 Views)
