DIAdem
Diadem does not recognise kvaser leaflight
Hello. I want to use a kvaser leaflight CAN-interface with diadem. However, Diadem is not able to locate it. I want to use Xnet for the input driver but my kvaser does not show up in the interface list. The kvaser does appear in the kvaser device driver so the problem seems to be in diadem. I have installed the kvaser interface driver and the kvaser diadem driver. I also tried installing the NI CAN software but this did not solve the problem.
Does anyone know why the kvaser leaf light does not appear in the list of interfaces while configuring the Xnet driver input? Has anyone had a similar problem?
(1,296 Views)
Hi Matthiast,
I did a quick search on the kvaser website. It seems that you need the Kvaser DIAdem driver and the Kvaser CAN drivers installed. Why do you want to install NI XNET and NI CAN?
The driver has to be registered in the GPI extensions and the functions of the driver to be added to the driver function groups.
DIAdem help entries:
  1. Registering GPI Extensions
  2. Configure Driver Function Groups: Driver Inputs/Driver Outputs
(1,256 Views)
Hello Colin!
Thank you! You are right, I registered the driver in the GPI-extensions and now it works perfectly!
(1,241 Views)
