DIAdem
Diadem measurements as output for actuators
Hello together,
I am working right now with DIAdem, serving as my data acquisition system for the test rig. Is it possible to use certain measured values, giving me a live output signal that I can work with?
I want to use these signals for controling actuators, that are part of my test rig.
Thank you for your help!
(2,256 Views)
Hi Solenoid_Valve,
it is in principle possible by using the "driver outputs" functions in the DAC Bundle of Diadem.
For example by applying the NI DAQmx Driver, and optionally the read/write buffer functions.
http://www.ni.com/pdf/manuals/374987d.pdf
Best Regards,
NI TSE
(2,207 Views)
