DIAdem
Diadem printing / pdf convert issue
Hello, when I want to print Report from Diadem or to convert it to pdf, result is with fontwhich seems to be condensed. Problem remains after update to Diadem 2015 and also print to another printer is not the solution. Printing of this TDR on another PC is OK. Thanks for any idea.
(4,794 Views)
Hi PavelP,
according to this thread changing the display resolution (decreasing it) might solve your problem. Please try it and report back if it worked.
Dániel Fülöp
Field Application Engineer (CLA, CTA)
(4,704 Views)
As you advised I decreased display resolution, from 2560x1440 to 1600x1200. PDF exported file is right displayed at decreased resolution and also at large resolution. How to solve it with natural resolution of my display 2560x1440? I would like to export and print right without change of resolution of display. Thanks for your help.
(4,639 Views)
Hi PavelP,
at the moment there is no permanent fix for this problem, just this workaround I described above. This might change in future versions of DIAdem. Thanks for your understanding.
Dániel Fülöp
(4,629 Views)
That's inconvenient, anyway thanks for finding reason of issue.
(4,620 Views)
