DIAdem
Diadem recuperate cursor coordinate using script
As a new comer on this site, I say hello to everyone.
My question is simple:
How can I get the values (X, Y) displayed on the curve of my report 2D graph using the "add curve coordinate" (right click on the curve) as input for a script, values that I use for further computation in this scirpt (basically the difference between Xs)?
I join a picture of that.
Moreover, I want to work with the Report and not the View.
I hope you can help me 🙂
To us all,
Louval
(6,163 Views)
Accepted by topic author louval
Hi Louval,
the function you are using marks any coordinates in your coordinate system but not a special point on your graph.
In DIAdem script is no object that refers to this function.
You can do for example:
Refer to peaks or other special point on you graph.
This could look like this:
Call ChnPeakFind("Example/Zeit","[1]/Drehzahl","[1]/PeakX","[1]/PeakY",4,"Max.Peaks","Amplitude") '... XW,Y,E,E,PeakNo,PeakType,PeakSort
So what do you want to mark? any point of the system or special points of the curves like in the attached image?
Kind Regards,
Philipp K
AE | NIG
(6,137 Views)
