DIAdem
Disabling Diadem script errors with Labview
Hi all,
We have programmed a Diadem script that runs automatically from Labview.
The problem is that when the script fails, the execution of the rest of the Labview program is blocked.
Would it be possible to disable the error pop-up in Diadem using Labview? I have already tried to send the 'AutoIgnoreError:=1' command in Labview, but it doesn't work (I am not sure if I used it properly... I read in an old post that this command is no longer available).
Another nice to have option would be getting the error code in Labview, but that's only a bonus 🙂
Many thanks in advance!!
(2,153 Views)
You can help yourself by making sure that the script does not break.
If you wrap your code by 'on error resume next' you will be able to prepare the error to be read by your labview code.
Option Explicit
' call main method
call main()
sub main()
  ' the main method will only take care of raised errors
  dim errorOccured : errorOccured = false
  dim errorNumber : errorNumber = 0
  dim errorText : errorText = ""
  ' will just go forward if errors shows up
  call workToBeDone() ' this method does the real job
  if 0 <> err.number then
    errorText = err.Description
    errorNumber = err.number
    errorOccured = true
  end if
  on error goto 0
  LogFileWrite "Result: errorOccured=" & errorOccured & ", errorNumber=" & errorNumber & ", errorText='" & errorText & "'"
end sub
sub workToBeDone()
  dim a : a = Data.Root.ChannelGroups(1).Channels("DoesNotExist").Name
  LogFileWrite "Not reached because of raised err"
end sub
(2,121 Views)
Hi Andreas,
Thanks for your fast reply!!
What about disabling the error pop-ups in Diadem when the script doesn't works? Would it be possible?
Many thanks in advance!!!
(2,076 Views)
Accepted by topic author lorunai1911
Just put a script beneath your script with the following content replacing "a.vbs" by your script name.
option explicit
scriptstart CurrentScriptPath & "a.vbs"
on error goto 0
Call this script instead  of the original one.
Or if you are interested in the eror:
option explicit
  errorOccured = true
end if
on error goto 0
(2,047 Views)
