DIAdem
Doing drift analysis over many files
I'm going to do a drift analysis to some current values (sleep/load).
Therefore I will look over the values of a day and filter for special temperatures.
Afterwards there's a mean calculation and I will save the day in a Time channel and the value in a data channel.
Is there any better solution for this or does this seem ok? Values I get are valid but it seems not that elegant.
So my solution works fine for one day and one device.
Is there a possibility to look over all files in a root folder and get only the data analized, which belongs to one device?
Maximum number of devices is 6.
folder strucure is like this:
Root
 - 20230701 (day 1)
   - device 1
   - device 6
 - 20230701 (day 2)
   - device 1
   - device 6
 - 20230701 (day 3)
   - device 1
   - device 6
 - 20230701 (day 4)
   - device 1
   - device 6
 - 20230701 (day 5)
   - device 1
   - device 6
in each device folder there is one file and there is much data that isn't needed.
I only need 4 channel groups out of 16 in each file but they shouldn't be deleted because they could be needed for other calculations.
Is there a possibility to walk through the devices and to the calculation to it and go on with the next?
I need the means of all 6 devices for about 3 months so at the end 90 times and 90 mean values in the result channel for each device.
As mentioned I already have it working for one day, but loading the data seems not that easy to me or am I wrong on this point?
Thanks in advance for your help.
Regards
Thorsten
(1,797 Views)
Accepted by topic author TLG90
Hi TLG90
I would suggest you use scripting in python or vbs to carry out your task. This is a very typical task which is often required. I've copied some python lines below from a similar script I've used with amendments to assist your task which you might find useful.
import os # import os library, first time used go to settingss and install os library in settings
for path in os.listdir(requiredFolder): # Iterate requiredFolder change this to your folder path
   if os.path.isfile(os.path.join(requiredFolder, path)) and ".tdm" in path: # ensure path is a file and .tdm file
      dd.DataFileLoad(path, "tdm", "Load|ChnXYRelation") # Load file
         channelGroupName = dd.Data.Root.ActiveChannelGroup.Name # get Group Name which is usually the filename
         myChannels = dd.Data.GetChannels(channelGroupName+"/*") # get the channels. Could select here
         for myChannel in myChannels:   # Loop channels
            if not (myChannel.Name == "Time"): # Could add further exceptions
               dd.ChnResult = dd.ChnStatisticsChannelCalc(myChannel,dd.eStatsArithmeticMean)
               print("The mean value from " + channelGroupName + " and channel " + myChannel.Name + " is :{:.2f}".format(dd.StatsResult(dd.eStatsArithmeticMean))
(1,736 Views)
Thanks for your suggestions and script.
I guess I have to do it with the os library.
This will help me to go further.
Thanks again
(1,716 Views)
