DIAdem
Double clicking report objects fails to bring up curve/axis definitions
Intermittent problem. Usually works by double clicking right after loading in a template, but then fails. Have to right click and select Display to bring up the definitions window (or any window for that matter). Just started doing this recently. Anyone else notice this? Solution?
(4,002 Views)
What version of DIAdem are you working with? I've heard of this happening with DIAdem 2012 SP1a. Back then it was fixed by a reinstall or repair. Can you give this a try?
Miles G.
Emerson Test & Measurement Group
Senior System Support Engineer
(3,976 Views)
