DIAdem
Drag and Drop with XTable
is there a way to enable Drag and Drop from the data portal in an XTable-ChnComboBox-Column?Just like in a normal ChnComboBox.
With best regards,
Martin
(5,665 Views)
Accepted by topic author MartinKozlowski
I found something 🙂
'do something with the dropped channel
Sub XTable1_EventDrop(ByRef This, Row, Col, DropInformation) 'Erzeugter Event-Handler
Dim oDropElement
  For Each oDropElement In DropInformation.DiademElements
    'put here some code for updateing table
    Call MsgBox(oDropElement.ChannelGroup.Name & "/" & oDropElement.Name)
End Sub
'enable drop for one channel in col 2
Sub XTable1_EventDropAllowed(ByRef This, Row, Col, DropInformation, ByRef DropEffect) 'Erzeugter Event-Handler
Dim oDropElement
  If (Col = 2) AND (DropInformation.DiademElements.Count = 1) Then
      If oDropElement.IsKindOf(eDataChannel) Then
        DropEffect = 1
      End If
  End If
End Sub
(5,660 Views)
