DIAdem
Drag and drop a signal into a combo-box
Hi everyone,
For a macro I made, I have to select a signal name from a combo-box that contains all the signals names in the group of my choice. However, I would love if possible to drag and drop the signal directly from the data portal to that combobox, which makes it quite easier to find.
As an example, we can take the view pannel. When selecting a signal, we can either search in a big list, or drag and drop the signal into that combo-box.
How to do it with the .SUD and VisualBasic scripts? By default it seems that draging and droping is not enabled.
Thank you in advance for your time and answer(s),
L911
(2,603 Views)
Well, for those who may be interested and did not see it yet, it exists the combo box and the channel combo box.
The former allows to add the values we want inside, including manually the names of the channel for example, whilst the latter directly contains the channel list; it permits to drag and drog the channel of our choice.
(2,577 Views)
