DIAdem
Enabling & Disabling frame display
I would like to incorporate some text objects into my reports and I was wondering if there is a method to diable the border around the object.
I am using DIAdem 2015 32 bit
Tim
(4,325 Views)
Accepted by topic author smoothdurban
Hello Tim,
Once you are inside the Text Object Editor in DIAdem REPORT, right click the mouse and you will have the option to uncheck the frame and make the text object transparent ...
It took me a minute to figure out as well, I was looking at all the options in the toolbar first. I'll ask if we can add that control to the text object toolbar in the future, that's where most people probably expect to find it.
I hope that helps,
     Otmar
Otmar D. Foehner
(4,314 Views)
Thanks Otmar.
I knew it existed but I had no idea where it was.
Tim
(4,305 Views)
