DIAdem
Error No. 11 Cannot open .MDF file
I am using DIAdem 12.0.0f4911 TDM and I cannopt seem to open this particular .MDF file.  The Error I get is  "XXXXXX.MDF" file has an invalid format.  (error no. 11)
I have opened other .MDF files without issue however this particular file is nearly 3 gigs in size.  Is it possible the file size it is too large?
Tim
Message 1 of 10
(7,659 Views)
The file size could really be an issue. On the other hand DIAdem is designed to work with data which does not fit into memory.
Maybe you can provide the file in question to
ftp://ftp.ni.com/incoming/
NI's write-only ftp-site.
Message 2 of 10
(7,656 Views)
The file has been FTP'd
its called WKThrustCollarSpinTest_2013-06-21_15-27-02.MDF
Tim
Message 3 of 10
(7,642 Views)
We have received your MDF file and can confirm that we cannot load it on our end as well.
We will now go ahead and analyze the issue - due to pending requests this will be earliest next week.
Message 4 of 10
(7,621 Views)
Not a problem.
Tim
Message 5 of 10
(7,596 Views)
We can now load the file, but figured out, it takes quite long (45 minutes) due to MDF file being unsorted.
Is there a pre/post process for sorting the MDF file, or do you expect all of your MDF files being unsorted?
Message 6 of 10
(7,567 Views)
I would expect them to be unsorted.
Tim
Message 7 of 10
(7,565 Views)
Accepted by topic author smoothdurban
Please find a new version posted to the web:
http://zone.ni.com/devzone/cda/epd/p/id/452
Note: The performance of the MDF DataPlugin is extremely better for sorted MDF files.
Message 8 of 10
(7,549 Views)
I loaded the MDF plugin and started DIAdem.
I have since loaded the data into the Data portal but DIAdem is cycling between "Not Responding" and "Responding" and has been doing so for over 2 hours now.  I am not sure if it is working, but I will give it some more time before I kill the process.
Thanks for your help nonetheless.
Tim
Message 9 of 10
(7,523 Views)
It eventually did load the data.
Thank you very much.
Tim
Message 10 of 10
(7,518 Views)
