DIAdem
Error: No common range of values in channels "7,1"
I have an error in Diadem v10 ( "No common range of values in channels "7,1"." ) with my script (It works properlly in v8.1) when the command  ChnMapLinCalc(CNo('Channel 1'),CNo('Channel 5'), CNo('Time'), 'DISPLACEMENT', 1, 'const. value', 0, 'analogue') works.
How can I configure correctly my v10 to avoid this error?
THanks in advance,
José
(3,587 Views)
Hi José,
I tried to evoke that error on my computer but I did not succeed.
Are you calling that line inside a AUT script (in that case the semicolon ; is missing in the end) or are you using a VBS script (then you should use standard quotes " " to mark strings).
Anyway, after changing the channel names to match the file I am using, the command is running well. Possibly the error has something to do with your datafile. So, if you want to attatch a sample of the file to the thread I could check with this data as well. It is possible that the algorithm performing the linear mapping changed between the versions 8.1 and 10 - but are you sure that this command works on the old version if you are using exactly the same data?
The error sounds as if the curve (Channel1 / Channel 5) does not match to the configured timechannel. If the new timechannel is exceeding the original x-range, DIAdem can extrapolate, but if the two x-rnages have no values in common, I would expect an error like that.
So I would recommend to doublecheck the content of the x channels.
Hope thius helps,
Ingo Schumacher
Systems Engineering Manager CEERNational Instruments Germany
(3,538 Views)
Hello again,
I've solved the error, it was caused due to an incorrect configuration in the xxx.stp "ASCIIConfigLoad" file, that loads a cutted time channel. I've solved it associating as default the extension of the imported file in the "ASCII-Import" dialog and increasing the number of rows to import in the xxx.stp file.
Thanks for your support.
Regards.
(3,480 Views)
