DIAdem
Error in copying curve (copy entry)
Hi, when copying a curve we got an error, can you check whats going on? .)
user has: Diadem 2017 64bit, win7
(3,556 Views)
Hi Lukas,
How did the user attempt to copy the curve?  Were they in the graph configuration dialog in REPORT, and did they click on the "Copy Entry" icon at the top right of that dialog, or were they doing something else?
Can you send the TDR file and the data set that reproduces this problem?
Brad Turpin
DIAdem Product Support Engineer
(3,530 Views)
Hi, it was in the dialog you are talking about, in report and clicking the second icon from left on right top of dialog.
it happens to me everytime in every graph
here is screen of the error on the TDR im attaching in this post
(3,508 Views)
Hi Lukas,
I loaded a random data file and renamed the Y channel to "15TUNNMIMIUPACXA", but I was able to load your TDR file and successfully copy the red curve in it using the curve configuration dialog.  I tested with DIAdem 2017 SP1 64bit on Windows 10.
Does this happen on other computers?  Can you translate the error message for me?
Are you able to send a data set that causes the problem on your end?
Brad Turpin
(3,504 Views)
I got Diadem 2017 SP 1 64bit on Windows 7 6.1.7601
It happens as well when i double click 2DAxis system to see curves in report tab and i press CTRL+SHIFT+C to copy all parameters to clipboard. The message box says that it cant find the file Report00CopyAsScriptHelper.VBC and i checked if i got the file and didnt find it in Diadem source folder, it doesnt exists on my computer.
(3,343 Views)
