DIAdem
Error in exporting REPORT image or HTML
I have been receiving an error recently while trying to export a REPORT into an image format or HTML.  I receive this error:
"Cannot open clipboard.  (Error code 0)"
Has anyone received this error before?  I have been able to export images and HTML files before, and I am not sure what I have done to change my system.
Thank you,
Julia
(3,805 Views)
Hi Julia,
exporting images is using the clipboard temporarily. Probably the clipboard was locked from a different program.
StefanZ
(3,798 Views)
I think I found the problem.  I have been experiencing clipboard problems lately with Microsoft Office products.  It appeared as though my clipboard would stop working after I would do a lot of copying and pasting.  Rebooting my computer fixed the problem.  After searching for help, it seems that my problem involves connecting remotely to a Windows 2003 server, which I do often.  If the connection is open, copying and pasting sometimes does not work on my computer.  It appears I am having a similar problem with DIAdem.  If I am remotely connected to a server, I cannot export images.  When I disconnect, everything works.  I thought that was a really strange problem, but maybe if anyone else has the problem, this might help.
Julia
(3,791 Views)
I seem to have the same problem when connected at the same time to another PC at distance.  If I close the connection to the other PC then the problem seems to go away.
(3,170 Views)
