DIAdem
Error using read TDMS example in MATLAB
I am trying to run the Dev Zone example, "Reading TDM/TDMS Files with The MathWorks, Inc. MATLAB Software."  Even when pointing it to the sample TDM file, I get this error:
??Error using ==>calllib
parameter must be a string
Error in ==> Read_TDMData at 39
err=calllib('nilibddc','DDC_GetFileStringPropertyLength',pfile.Value,DDC_FILE_NAME,pfilenamelen);
I am using Matlab version 7.0.1
I have found other posts referencing other errors, but none with this error.  It looks to me that this version of Matlab is supported and should work.  Anyone have any ideas?  Thanks you.
-Chris
(4,476 Views)
Hi Chris,
There is a KnowledgeBase article [link no longer available] that I found that looks to be the same as the example you were using in the Developer Zone.  I would like you to try this one out as well just to confirm that it is.  It mentions in this article which versions of MATLAB are officially supported.  As you are using an earlier version which has not been tested, it is possible that this may be the reason why it is not working.
Cheers,
Kelly R.
(4,434 Views)
