DIAdem
Error while loading TDR file through script
     I have created many Report templates (TDR files) and load them in my script. However, while loading one of the TDR's using the PicLoad command, DIAdem throws an error saying
"Error while opening the file "C:\PROGRAM FILES\NATIONAL INSTRUMENTS\DIADEM 11.0\Bosch ToolBox\Template\AllVBS Test.TDR".
I am really at a loss, as I am unable to proceed with the Report generation, which I need to test urgently. Kindly suggest a way out.
It may please be noted that I am ABLE TO OPEN THE SAME FILE in the Report Panel using File->Open. Incidentally, all other template TDRs are getting
loaded without issues, through DIAdem script.
Thanks in advance.
Regards
Venkatesh Murthy.
(4,994 Views)
Hi Venkatesh,
Have you tried manually loading the TDR and re-saving it under a different name?  Can you send us the TDR file that is misbehaving?
What happens if you start DIAdem fresh and then execute the single script line "Call PicLoad(LayoutFilePath)"?
You might check to see if the name-expansion mode is turned on or if the layout is in numer-referencing instead of name-referencing mode.
Brad Turpin
DIAdem Product Support Engineer
(4,970 Views)
Hi, I just got here via google and my problem was between chair and keyboard: ;]
Doublechcking the path helps:)
(4,087 Views)
