DIAdem
EventSearch on strings and fill data until next occurrence
is there any kind of EventSearch for text data?
I have a channel group which contains sequencer commands.
I need to search for "SET:ColorScreen:ALL" and sort values of a current channel to them.
The sequencer writes the timestamp only for the time a sequence command is given.
The current path's frequency is 1Hz.
So the amount of values isnt't matching and I would only need the values until the "SET:ColorScreen:ALL" command occurs again.
Is there a simple solution to do this?
Thorsten
(1,161 Views)
Dim i
For i = 1 To Data.Root.ChannelGroups("Sequencer").Channels("Sequence command").Properties("length").Value Step 1
  Call LogFileWrite("Found 'SET:ColorScreen:ALL' at row: " & str(ChnFind("instr(1,ch(""Sequencer/Sequence command""),""SET:ColorScreen:ALL"",1)<>0", i)))
  i = ChnFind("instr(1,ch(""Sequencer/Sequence command""),""SET:ColorScreen:ALL"",1)<>0", i) + 1
(1,094 Views)
Thanks for that.
Helps me to find the string.
Didn't think of a solution like this.
(1,078 Views)
