DIAdem
Excel calculation in DIAdem for Peak Sun Hours
I am trying to perform a calculation for peak sun hours in DIAdem that we typically perform in Excel.  Any advice on how to approach this calculation in the DIAdem environment much appreciated.
(4,996 Views)
Accepted by topic author moses_montoya
Hi moses montoya,
I was able to recreate the Peak Sun Hours data with the following script.
Dim PeakSun, intLoop
PeakSun = ChnAlloc("Peak Sun Hours")
Data.Root.ChannelGroups(1).Channels("Peak Sun Hours").Values(1) = 0
For intLoop = 2 to (Data.Root.ChannelGroups(1).Channels("Channel 2").Size - 1)
  Data.Root.ChannelGroups(1).Channels("Peak Sun Hours").Values(intLoop) = Data.Root.ChannelGroups(1).Channels("Peak Sun Hours").Values(intLoop - 1) _
  + (Data.Root.ChannelGroups(1).Channels("Channel 1").Values(intLoop) - Data.Root.ChannelGroups(1).Channels("Channel 1").Values(intLoop - 1)) * 24 / 1000 _
  * Data.Root.ChannelGroups(1).Channels("Channel 2").Values(intLoop)
Channel 1 was the time, and Channel 2 is the irradiance.
Brandon V.
Applications Engineering
www.ni.com/support
(4,977 Views)
Brandon,
This did the trick and gave me some pointers on how to deal with some of our legacy Excel files.
Thanks for your help!
-mm
(4,969 Views)
Hello moses montoya,
Anytime!  I'm glad it worked for you.
Brandon V.
www.ni.com/support
(4,967 Views)
