DIAdem
Excel data loading
Pls find the attached excel data which contains section name and date as the first two columns. If I delete these 2 columns, I am able to load the data using plugin wizard without any problem. If I try to load without deleting these two columns, I am not able to load it properly. Pls help me in loading the entire data without truncation as the date and section name is very important for me.
X. Ignatius
(5,835 Views)
The reason that the Excel wizard is not able to open the file is that it is not an Excel file, but a CSV file with XLS extension.
Instead you can use the Text DataPlugin Wizard to create a DataPlugin for your files.
(5,822 Views)
Dear USAC,
I tried opening using ascii csv plugin. It opened but I am not able to view the date column which is in the file. My ultimate aim is to plot the date(X-axis) vs different channel(Y-axis). Is this possible with the file attached?
X. Ignatius
(5,813 Views)
Hi Igni,
Please see my answer and posted DataPlugin at your other duplicate post.
http://forums.ni.com/t5/DIAdem/Excel-data-loading/m-p/2733695/highlight/false#M18209
Brad Turpin
DIAdem Product Support Engineer
(5,804 Views)
