DIAdem
Excel import wizard
I would like to import excel files by using a configuration file. Normally I do this using the Excel import wizard. I want to find out if it is possible to write a command in the script so I can just drop in any excel files and it automatically adjust.
Does anybody know how to do this?
greets,
Robert
(3,879 Views)
Hi Robert,
Have you tried the "ADO" DataPlugin at www.ni.com/dataplugins?  This will load any Excel file into DIAdem, making the assumption that each column should be a channel.
Brad Turpin
DIAdem Product Support Engineer
(3,863 Views)
I already have these dataplugins. Indeed, they assume each column to be a channel. The problem is that the data acquired fills in * in cells that have no values. So these cells have to be ignored what i do with a configurationfile in the wizard.  I would like make a command that does this automaticallyn if it's possible because i have hundreds of files to analyse.
Is this possible?
greets,
Robert
(3,859 Views)
Hi Robert,
There is no way to automate the creation of the STP file that I know of, short of using ASCII commands to build up the STP file from scratch, and I don't have any information as to the structure and contents of the STP file.  I know some customers have worked on this with the ASCII Wizard and resulting STP files, but I don't know how to help you do it.
If your Excel files are not too big, you, might consider instead building the desired intelligence into an import script or a DataPlugin, and in both cases it could be built on either ADO technology or ActiveX technology.  With this approach you could evaluate cell-by-cell and reject any empty cells or import the file differently depending on what values you find in particular cells.
Brad Turpin
(3,836 Views)
