DIAdem
Export channel data to ascii format in diadem
I am using Diadem 14. Is there a way to export analog channel data to ascii format? Or is it possible to create a script for the same?
The output file that I need has to 2 columns with first column containing the x channel (time) values and the second has the y channel values.
Regards.
(5,742 Views)
Call DataFileSave("C:\temp\data.csv","CSV")
 Call this line. If you need different delimiter have alook at this link.
(5,737 Views)
Thank you for the response.
I have a time channel ranging from 0 to 100 sec, and I want to export the channel data from 25 secs to 50 secs only. Is there any modifications of the above command to meet my requirements.
Regards.
(5,716 Views)
Hi faz_shah,
Yes, you will need to programmatically create a new Group in the Data Portal which has only the subset rows you desire in it.  If you post a data set, I can help you with the necessary code.
Brad Turpin
DIAdem Product Support Engineer
(5,606 Views)
Got it.
Wanted to know if there was any easier method.
Thanks.
Regards.
(4,996 Views)
