DIAdem
Export graph from DIAdem to Excel
 I am new to use DIAdem and I have a question about saving graphs from DIAdem to Excel (not an image). Is there a solution or script to do this?
And a second question please, how do I export DIAdem report  to PowerPoint, for example a table as a real table and not as an image?
Thank you in advance,
Ghizlane,
(1,826 Views)
Accepted by topic author GhizlaneDligui
Hello Ghizlane,
first, the graph in Excel or Powerpoint is just the visualization of the data available there.
You can change the colors, lines, axes etc, since it's only the changes in visualization mode.
If you need to change anything on the visualization mode of data in XLS, you need these data in the program.
Means, it wouldn't help to transfer only the diagram; you need the "source" transferred too.
Maybe this simplifies your purposes 🙂
Greetings,
Vassili
(1,785 Views)
Hello Vassili,
Yes, I just want to be sure about that.Thank you for your clarification,
Greetings,
Ghizlane
(1,770 Views)
