DIAdem
Export to CSV
Hello everyone,
I want to store all data in CSV file. Unfortunately it writes the time down as following:
08/12/2009 13:50:00.000000
I would like to have another format, like this:
12.08.2009 13:50:00.
P.S.: When I export it like xls file then the time is shown like I want. The time format settings of Diadem I changed like:
#dd.mm.yyyy hh:nn:ss
Can you please explain me why xls works and csv not?
(5,498 Views)
I assue you are in geramny and you do not only want to change the time format but also decimal point and separator.
Option Explicit  'Forces the explicit declaration of all the variables in a script.
if "IDOk" = FileNameGet("Any", "FileWrite", "*.csv", "German CSV (*.csv),*.csv") then
  dim csvFileName : csvFileName = FileDlgFileName
  dim additionalParameters : additionalParameters = "<decimalpoint>,</decimalpoint><delimiter>;</delimiter><timeformat>DD.MM.YYYY hh:mm:ss.ffffff</timeformat>"
  Call DataFileSave("<filename>" & replace(csvFileName, "&", "&amp;") & "</filename>" & additionalParameters,"CSV")
end if
 The following script will do the job.
Greetings
Andreas
(5,485 Views)
thanks for help.
But I've got an error message. That the file cannot be created. I set csvFileName = autoactpath & "\export\" & "test.xls".
<filename>csvFileName</filename><decimalpoint>,</decimalpoint><delimiter>;</delimiter><timeformat>DD.MM.YYYY hh:mm:ss.ffffff</timeformat>
(5,427 Views)
Does my attached script work out of the box?
Your line has to be
"<filename>" & csvFileName & "</filename><decimalpoint>,</decimalpoint><delimiter>;</delimiter><timeformat>DD.MM.YYYY hh:mm:ss.ffffff</timeformat>", "CSV"
 else the csvFileName is not threated like a variable.
(5,413 Views)
No, It's not.
I copied it to my skript like this:
  dim csvFileName : csvFileName = autoactpath & "\export\" & "test.xls"
And after starting it, I got an error message, that a file with name
<filename>test.xls</filename><decimalpoint>,</decimalpoint><delimiter>;</delimiter><timeformat>DD.MM.YYYY hh:mm:ss.ffffff</timeformat>
cannot be created.
(5,405 Views)
Look currious. The target directory has to exist. It will not be generated.
dim csvFileName : csvFileName = "C:\temp\" & "test.xls"
Works for me. While "C:\temp" exists on my machine.
Which DIAdem Version do you use.
(5,400 Views)
I don't use Option Explicit.
I use 10.1 Version.
(5,395 Views)
